test
Within this forum you can test the extensions. For viewexif, simply create a topic and attach a image of your choice. You can check if the exif data of the image is read correctly. Please use the user "Tester" with password "test123"
Forum rules
Topics in this forum will be deleted after 30 days. If you find any problems with my extension, please use the report-function (exclamation mark on the right top of the post).
Please use the user "Tester" with password "test123" or register a user for yourself.
Tester
Test user
test
Post by Tester » 04 May 2019, 14:12
test
You do not have the required permissions to view the files attached to this post.
I am the boards default test user. Everybody can use me. My password is written in the Test me-forum
